setting the pressuretrol???
Joe_39
Joe_39 Member Posts: 47
  • Joe_39
    Ive got a honeywell subtractive pressuretrol
    right side say main and has numbers 2, then 5, then 7 i believe.. etc
    left side is differential (subtractive) and says 2, then 3, then 4
    Ive got 1 pipe steam
    what should this be set to??? right now its a little below 5 and on the subtractive side its set to 2
  • Dan Goodridge
    Dan Goodridge Member Posts: 62
    Looking at the psi scale -- Set the main to 1.5 and the differential to 1
