setting the pressuretrol???
Joe_39
Member Posts: 47
Ive got a honeywell subtractive pressuretrol
right side say main and has numbers 2, then 5, then 7 i believe.. etc
left side is differential (subtractive) and says 2, then 3, then 4
Ive got 1 pipe steam
what should this be set to??? right now its a little below 5 and on the subtractive side its set to 20 -
Looking at the psi scale -- Set the main to 1.5 and the differential to 10
- 114 Geothermal
