What is this
Question the placement of this flow check. Are you SURE it's on a return?
The valve handle was "appropriated" after the "lever" broke, when trying to open it for one reason or another. I recently saw a similar modification, but it was definately on a supply line, where it belonged. The leak from not tightening the packing nut upon install and commisioning leaked early in its carreer and rotted out the lever, right around the set screw. When someone tried to flip the lever, it was split, and fell(spilt?) right into their hand. Chris
