Controls
MW_2
MW_2 Member Posts: 25
Be aware that the Taco pc700 opens the TT boiler contact to acheive the desired system temperature according to outdoor temperature. This will also cycle the boiler pump off which often results in a rapid decrease in system temperature and boiler short-cycle issues. I have had better luck by opening and closing only the burner circuit when using the Taco system.
