Controls
MW_2
Member Posts: 25
Be aware that the Taco pc700 opens the TT boiler contact to acheive the desired system temperature according to outdoor temperature. This will also cycle the boiler pump off which often results in a rapid decrease in system temperature and boiler short-cycle issues. I have had better luck by opening and closing only the burner circuit when using the Taco system.
TACO vs. HW AQ
Looking for anecdotal information.
I have a numberr of apartment buildings that want me to install controls to automate to WWSD and potential savings of ODR. Multiple zones, baseboard heat, WMC CG boilers.
My obvious choices are either a TACO system including ZVC's and the PC 700(?), or the HONEYWELL AQ series. The Taco I have done before, the HW is not so prevalent in out area, probably marketing is the reason.
The price is nickel/dime different.
Can you guys give me some user/installer comparative feedback on ease of install, functionality, reliabilty, etc.
Are
you including the required T'stats in the AQ price?I like them both,if there is already a Taco EXP panel I use the PC700.If I'm starting from scratch,the AQ.
In a landlord situation the AQ has the ability to set a max temp on each zone
Been there done that!!! It made perfect sense after way too long to figure it out!
I didn't...better look into that!
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
