new boiler pics
Old to new
Mr Rich Ferris and i did this one on tue and finished the wiring and clean up on wed morning.
Great job Rich !!!
Yes thats my mug shot...:-)
Warrm
Boy - a radiator to keep the boiler warm. Now that's thinkin'!
Nice looking job, though. Good work.0 -
Nice job as usual David. How do you like the preformance of the 32 gallon tanks? 2 ?'s for you- any grief from the inspector about no baro dampner? And, how come that Riello is pushed so far into the chamber?0 -
Hi Ray
Tha boiler dose not require one and if the boiler specs say so, so will the inspecter,he goes with what the boiler mfg calls for. the tube calls for the depth its at...i was aking rich about that and he said it calls for 10 depth..seems deep huh...DAvid
Boiler
Nice!0 -
Indeed,
Nice.0 -
you cleaned that mess up,
looks very nice.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"gwgillplumbingandheating.com
And you forgot to mention the help you had
from Dr. Pepper...
I am seeing a tradition here.0 -
Nice install Dave and Rich
I like the extra effort involved with the blocks under the boiler . Servicemen can actually sit on a bucket to do a tuneup . Have you been using that type Buderus indirect for a while ? How are they lasting ? We're looking for something a little less heavy than what we use now . Every indirect is a 2 man job nowadays .0 -
Nice job David !
I too, like the radiator that keeps the boiler warm.
One question...Why did you retain the old style circulator? Was it a price thing?
Nice to see the jumble of pipes "before", disappear. I'm sure the homeowner will be very happy with his new fuel bills. Chris0 -
That circulator had just been installed recently
In defense of the circulator question. That 110 was supposedly installed recently by another company and it cost the customer quite a bit. Seems they had replace an older 110 with a 007 and had nothing but problems with the radiant system. She really didn't want me to change it out. So in turn it was a cost thing. As far as the tube length goes the spec is 10". Yea HMMMM as David would say.
Thanks,
Rich Ferris0 -
Thanks Rich.
I knew there HAD to be a reason! Chris0 -
Ahhh only the finest from Ranger Dave! How are things? I bet you have been doing some great camping trips this summer!
liner?
was a chimney liner required for that install?
ss
Can't tell from the photo
Is that 3/4 to the indirect ?
Nice neat work.
Scott
Very nice....
... the jumble of pipes and other thingamabobs is tamed, pruned, and leveled. Another happy homeowner, no doubt.0 -
Hi Josh
Yes Rangers had a great year this year!!!!
110 circ
If I may say so, it is nice to see the old 110 in the pic. I can honestly say, regardless of the size, and price, and a few other issues, it is a great pump. I would never fall short of standing up for it.
( Guess I have to say I'm SLIGHTLY partial to the 00 series!!!!!)
But, believe it or not, we still sell quite a few 110's.
I really enjoy this wall time. You guys are really great.
By the way, wait till you see the stuff we have coming down the line for you in terms of new products. Stuff you've asked for, stuff you want.
Don't forget one of my main reasons for keeping this company private and running it the way I do: IT'S ALL ABOUT YOU!!!
Johnny White0 -
Thank you Johnny !!
Its men like yourself that keep us growing and doing things better ! Thank you for the compliment...David
What I'd like to see
John , I've been using the Taco line since I started in 1986 , and by far your company makes the most dependable products on our systems . At least one LWCO , pressure reducer , relay , air eliminator , and a few circs on every install . 3 or 4 boilers a week for decades , and that's just me .
What I'd like to see , and I'm not even sure if it's feasible , is a circulator with built in temperature regulation for radiant . Something with mixing abilities in the circ itself , It would simplify multi temp systems dramatically .0 -
Great call Ron !!!!
I too, would like to see the pump built into the mixing device.
We've used quite a few of the 3 way mixers, but if the pump was put in the right place..these would be the bomb ! (John, are you listening?)
I would also like to see the multi-speed function on the "green guy".
As an aside...we recently had a rep from Emerson Swan out to our shop for some in house training.His first comment was..."I see you use Grundfos pumps with most of your installs...are you running them on the MED. or High setting?"
When I told him that in most instances, we are running them on "LO", he said..and I quote" That's the same as our 005/6!". He's right! But.... most of the systems I look at are considerably "over-pumped"...to a fault. When it works on "LO" it is always a good thing. If it doesn't ...then bump it up to MED, and it's the same as 007-008, with few acceptions.
I like AND respect John, and his company for what they bring to the table. I use many of their products day in and out...but would truly love to see the technology for variable/multi-speed brought into their line. I think it would be a great solution to the question asked in a recent post. (for the record, while waiting for someone to show up to let me into a job one day, I was sitting on the bench out front....reading the cut sheets from a few different manufacturers. I noticed that the G UP15-58 will cover ...from a 006-up to the 0010 W/ifc, using the different speeds available.
Taco has the 3 and 4 way mixers available now. They also have the circulators with a built in relay for each....I don't think it would be a stretch to combine the 2 and make a world beating "multi-utilitarian, all-in-one mixing/tempering device...for anything that may arise".
So Johnny...Whatdayathink? Chris (P.S. I want MY cut!) JCA0 -
Thank God for high rubber boots ;-)
quick
If you don't mind, I will get to these issues early in the week...I'm sort of on the run now.
However, please don't for a moment think Taco is sitting around not doing anything technologically. What is coming, as I said yesterday, is really great. Also remember, all of what we do is for THIS market, not a by-product of another. This is VERY important.
Be very careful on LO speeds of starting torque issues. Just a recommendation. Nothing negative here, because I totally respect what is out there and the reasons for people using whatever. Just a thought...I've been at this for almost 30 years!!! I've actually retained a few things I've learned.
Anyone is welcome to call me at Taco and chat any time. This input is increadibly valuable.(#401-942-8000)
Have a wonderful weekend!!0 -
Looks like a great bunch of boys. I can't wait until Hunter is a few years older.
BATTLESHIP COVE
Looks like a visit to Battleship cove in Fall River Mass. Went with our den last year and spent the night! What a great trip. Can't tell you who had more fun, the boys or the "Big" boys.0 -
Vent Damper
A vent damper would be required if the draft exceeds what is needed at the breech of the boiler. Riello's like zero to slight positive over the fire. Install looks great. The Logamatic should provide some nice fuel savings.0 -
Morning Joe
Yes you are so right!All i can say is wow! i had a great time there(so did the boys )i was realy amazed with all that i saw, Boiler rooms were cool...Cant get to close thu, Bet Dan would have fun in there;-)....David
In response to your message regarding the 3 and 4 way mixers, circulators with a built in relay for each, these two products have already been married into 1 product, hence the Radiant Mixing Block, RMB-1. Taco, also offers the variable speed circulators for mixing, and injection. For your reference I attached the Radiant Variable Speed Outdoor Reset '00' Circulator informational data sheet.Joe Mattiello
Taco Comfort Solutions0
- 167 Indoor-Air Quality
