Correct percentage
Empire_2
Member Posts: 2,340
With 1/2" baseboard I believe there should be only 25 ft of affective base in the circuit that will provide you with 15,000 btu @ 20*Del T. I guess as long as you are not going to excessive lengths between base, this should hold. The guy's are sharp in here and will set your mind at ease.
Mike T
Mike T
I am wondering something regarding baseboard hot water heater footage: Generally speaking (if all rooms are similar in size, what should the percentage be in the 1st 1/2 of the loop versus the end half of the loop? I know that you want less heater footage in the 1st half otherwise the cooler water would not warm the 2nd part of the house equally - but how much less? I am looking for a rule of thumb and realize that the true test is actually trying it out in the middle of winter to see if there are hot rooms or cold rooms. I am guessing that perhaps it should be something like 35% in 1st half and 65% in the last half. Is there a formula that you can use based on square footage per room?0 -
Formulas
for determining this are included in the HDS oftware and also Modern Hydronics. this article sheds some light for you.
http://www.pmmag.com/CDA/ArticleInformation/features/BNP__Features__Item/0,2379,4093,00.html
hot rod
Hot Rod
You helped me out with the web sight. Love it and cannot waite to play with download. Always nice to have tons of info.0
- 110 Chimneys & Flues
- 978 Plumbing
- 387 Solar
- 17 Recall Announcements
