Leak Detectors
Marty
Member Posts: 109
http://www.bacharach-inc.com/h10g.htm
Thats for the H-10 most sensitive thing I have ever used. Thats assuming they are still made the way GE was making them Probe died on mine years ago when D-tek came out with their first generation of 134a dectors Bought one of those its almost as good. Pretty impressed with the tek mate one also for a battery powered detector its not bad at all.
UV is pretty much useless,,besides the only thing that should be floating around in a system is refrigerant and oil.
What kind of...
Leak detectors are you guys using. I have a Tiff, I think a model 5050? I just don't trust it. It seems to go off for no reason. I always fall back on the old reliable soap bubbles.
How about it. What works best?
What I Presently Use
I like to bring a variety of leak detectors into my classes so my students can get a feel for the wide variwty of options they have when it comes to leak detection. One of my latest goodies is this model from Inficon. It works great.
http://www.inficon.com/download/en/D-TEK_CO2.pdf0 -
Leak detector
I have a MARS (GE-Yokogawa) H10. Best I ever owned. versatile, sensitive, dependable. Never failed me. I find the leaks no one else without one can. Only drawback, but not insurmountable, is it is 120VAC powered. They do make a battery powered version I'm told.0 -
Thanks
The infocon looks pretty impresive. It doesn't say what refrigerants it will detect. Does it do all of them?
I can't find any info on the Mars unit. Do you have a link Ken?0 -
Don't forget
The Ultra Sound detector. I use it along with halogen sniffers to find leaks.
Mike T.0 -
Go Pro
Ultra Sound .....0 -
bink
Has UV Fallen off the Radar?
What's your take on UV guys?
What percentage of your customers presently have UV solution in their systems?
That's why I'm asking
Exactly why I'm asking, Marty. It's very difficult to install a breans new system and then risk having the compressor manufacturer not honor a warranty because of "foreign" substances in the system.0 -
why put it in a new system?
People put that stuff in on new installs ? Almost Anything gets warrentied unless its a multiple repeat failure or you are returning half of what you buy in warrenty. I've found leaks with bubbles and my battery powered tekmate that someone had looked for with the dye and not found. A decent leak dector and a nitrogen/22 mix is a better way in my opinion. may not find every leak but I have tried the light on systems that have small unfindable leaks and they remain unfound.
It Used to be Very Common
Many installation companies would inject the dye on newly installed systems so that, in the event the system would develop a leak, the technician would be able to utilize the UV light on the first visit.0 -
I like
to use all three . It depends slow leak 1 lb a year UV fast leak dry in a week elect. want to spend $$ dry N. have found with all and none of the above
ps what about looking for oil ?0 -
HA HA
Like Dlux I first look for the oil stain, the I get my halon torch and sniff around. Then depending on the leak I pump down the system close the service valves and add N. (nitrogen) up to 400 psi(do not make that face Professor it will be OK) Soap, halon torch, and whistle I will find your leak. Best Wishes J.Lockard0 -
Me?
Make a face?
Never!
But one question... why would you want to exceed the maximum test pressure of the system's coils?0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 986 Plumbing
- 389 Solar
