scariest installs for halloween
Tony_23
Member Posts: 1,033
The homeowner thought this was caused by rainwater, all winter. Then claimed it had never pumped flue gas out the water heater draft hood before.
show the scariest installs for halloween.
Show us the most rude, scariest installs you have ever seen, if you have the pics to do it. Tim0 -
I've seen
I've seen worse than this but here's a start..0 -
BBBBOOoooooooo
This one will make the hair on Dave Yates neck stand up. It's a combination system serving an old folks home....
Makes me want to cry every time I see it.
ME0 -
More ugly...
crapsmanship at its finest!
ME0 -
ya gotta love the color coding though........0 -
One more
This was a service call..used to much oil..0 -
hay mark you have to say alot of thought went into that one.
hee hee ;-)0 -
Is that fuel oil all over the floor? Oh my god!0 -
So many pictures................
so little time. High end heat for high end homes.There was an error rendering this rich post.
Here's a fright
Happy belated Halloween .0 -
HB,
Got any more pics of that "mixing device" ?
That's got to be about the scariest piping one so far....but LCHMB and the oil boiler on the pallet, with all that fire server at the base has got to be the winner ....so far. BOO!
Ron, definately scarey, but tags will go out in short time compared to that pallet. BTW M.E....That birds nest STILL looks the same! (I got called out there a couple weeks back!) Chris0 -
Scary
Here's a few... -DF
Here's another
I replaced this one last month0 -
Here's another
I replaced this one last month!0 -
I love the never ending loop...just try and isolate it....and the flexi vent!!!
TJust a guy running some pipes.0 -
compactor
This looks like the *after* photo when a 1968 Lincoln comes out the compactor at the wrecking yard.
This wasnt
The install on this furnace wasn't bad, but when I got there for a no heat call I was a little curious. The woman was talking how everyone in the house had been sick...Wonder why??0 -
Great picture...
... an alien spaceship landed in the flue pipe, then escaped from the combustion chamber! :-)0 -
Have noticed this for about 5 years. Yes, that's the outer case of a central A/C condensing unit and yes, the chimney is in use. Note the slight angle to make it "safe".0 -
Code Police!
Where are the code police when you need them! There doesn't appear to be very much mortar on the top 3 or 4 courses of brick either! Holy Cow!0 -
she's a beauty
From a couple years ago
cluster ****
Is this a DIY job or done by a pro?0 -
Is that...
... the heating professional taking a bow before this mess to appease any ghosts before he rips it out? :-P
Lots of nice components that meet spec, etc. installed in a most haphazard way. What a waste of good materials.0 -
sweet baby jesus!!!
Am I seeing this right? Did he encase and seal a box around the furnace, cutting off combustion and dilution air. vent it horizontally with C vent through the wall with no exhauster, co vented with the HWH, went DOWN into the common, has no natural draft, added a dryer vent hood to the end of the pipe, and faced it into the building wall? where flue gases of 300-450° will exit, NEXT TO a window!!
If he aint dead...kill him and clean the gene pool, cuz he is tryin to commit suicide...
no one ever NOTICED THIS BEFORE YOU!?!?!?!?!?!0 -
WOW
I almost vomited up my breakfast after seeing those pictures. I wonder how that moron is still alive. A perfect example of someone that knows just enough to be dangerous- literally.0 -
found em.
Or is he...
...praying for guidance to troubleshoot?0 -
this was running when we pulled it out,plenum was holding it up0 -
Boiler room mess
I posted this originally over at Hvac-Talk.
Anyone interested can read the whole story here.
[url]http://hvac-talk.com/vbb/showthread.php?threadid=36379[/url]0 -
Boiler room mess
I originally posted this over at Hvac-Talk anyone interested can read the whole story here.
http://hvac-talk.com/vbb/showthread.php?threadid=363790 -
well...
No, no one noticed this before me because the installer (DIY) has been repairing it. The installer is a relative of theirs, which explains the dumb looks I got when I blew a gasket and wouldn't make it run but got my camera instead
She said, "It's worked okay so far, why not just fix it ?" When I explained the danger she said they always keep a basement window open and only use it until it gets real cold when they switch to the coal heater :0
The dryer hood was an attempt at keeping out the "rainwater" that kept dripping on the HSI and shorting it out. That window is the master bedroom...
Trains and brains...0 -
Gawd! Whata bad joke!
i havent laughed so much since the Bent handeled job we were called to....That is Brutal! not even the Duct Tape made any improvement*~/:)) that is Extremely Sah Vere...0 -
WHEWS!.....
What can i say....?0 -
What?
No barbeque????????0 -
bump...Just a guy running some pipes.0 -
Before and After
ahhhhhhhhh!!!!!!!!
looks like an f5 twister sucked through there!!!!0
- 167 Indoor-Air Quality
