scorched air restrictions
Timco
Timco Member Posts: 3,040
I just read in this morning's paper that Provo, Utah will begin enforcing a new code where multi-unit structures can no longer share the same air-recirc system, or furnace. I am considering writing the cheif building inspector and suggesting some insentives for radiant, which would fit the bill nicely. The article complains about how expensive individual furnaces will be, and I feel they are just missing the obvious. Would you guys suggest steam or HW? Any other ideas to suggest?
T
Just a guy running some pipes.
  • Darin_3
    Darin_3 Member Posts: 27
    In Michigan most inspectors enforce the no shared air rule which changes the cost of alot of remodels considerably. If you need ac, your screwed without seperate systems.
