scorched air restrictions
Timco
Member Posts: 3,040
I just read in this morning's paper that Provo, Utah will begin enforcing a new code where multi-unit structures can no longer share the same air-recirc system, or furnace. I am considering writing the cheif building inspector and suggesting some insentives for radiant, which would fit the bill nicely. The article complains about how expensive individual furnaces will be, and I feel they are just missing the obvious. Would you guys suggest steam or HW? Any other ideas to suggest?
T
T
In Michigan most inspectors enforce the no shared air rule which changes the cost of alot of remodels considerably. If you need ac, your screwed without seperate systems.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 966 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 44 Industry Classes
