Boiler replacement job photos ( s milne )
joel_19
joel_19 Member Posts: 933
well it's hard to count the sections with the jacket on...
So would you use Tekmar on a Buderus ? Do you not use the Vitotronic 200 or 300 controll ? interesting , personally I find Tekmar controlls alot more frustrating than the Viessmann stuff . With Tekmar it always seems like there's one more thing i want to do but can't without buying another control . We use alot of them but for add on radiant and stuff . The mixing block thingy is really slick we are putting 2 in this week. and I just sold a Tn4 to a customer with a screwed up commercial biulding , that should be cool.
  • ScottMP
    ScottMP Member Posts: 5,882
    I wish we had taken
    before photos.
    This is an apartment building that we have been talking to the owner about replacing. He had a Wiel-Mclain 66 series with an economite gas conversion burner. The return piping was a spider web of piping.
    No Longer.
    Chris A. and "new guy" Kieth did the install. Kieth worked back at the shop and prepiped the manifolds while Chris cleared the room of old piping.
    I had originally quoted two Buderus that would be staged but to cut cost we were able to get a good price on the Viessmann RN 280. My supplier had one left over since it is no longer made. Too Bad its a nice boiler. Its a two stage boiler so we still get the right amount of out put for the demand.
    The electrician we have found is a perfect fit for our work.
    We installed a Tekmar 262 for the staging (which happens in the boiler) also in anticipation of a future indirect. We have four and five zones so he have one pump for each manifold and then PDV for each manifold to balance the flow.
    Don't look at the gas pipe :) We did'nt change that.
    Scott
  • Mark Hunt
    Mark Hunt Member Posts: 4,908
    Beautiful work!
    Nice and neat as uaual.
    (Except for the gas pipe)
    Mark H
  • Eugene Silberstein 3
    Eugene Silberstein 3 Member Posts: 1,380
    Very nice
    Good work Scott. A nice, neat looking system seems to run better than one that looks like c***.
    At least that's what my father told me about the car when I was a kid. "A clean car drives better than a dirty one". The jury is still out on that one.
  • John Boyer
    John Boyer Member Posts: 60
    Great
    Great looking job, Scott. I like the controls, manifolds and the purge valves. I have never seen that model boiler before. Which current model replaced it? -DF
  • Dale
    Dale Member Posts: 1,317
    Elect work
    Really nice looking supply wiring, I really like that GFI being added to the mix. Nothing like a safe elect. source arround a perfectly grounded boiler. That big gutter will make any future work so easy.
  • ScottMP
    Dale
    Thats something we have asked for. We want a plug installed for service work, near the boiler.
    Scott
  • Constantin
    Constantin Member Posts: 3,796
    Great Job!
    I hope the client likes orange! :-P
    Lots of neat touches, like the document holder, orderly piping, an LWCO, comfortable-to-work-on electronics mounted out of the way of spraying water, a very nice manifold with all the drains and shutoffs a technician could dream of, etc.
    This system is a joy to behold, not only because it has been piped well but because it also minimizes the number of pumps necessary to distribute the heat. I used Siggy's program to see how much pumping our home needs, and it's not one pump per circuit.
    So, congratulations to all the good help that got this project to where its come.
  • Paul Rohrs_4
    Paul Rohrs_4 Member Posts: 466
    Scott.
    I fully appreciate having a skilled electrician on board that takes as much pride in their work as you do. It really helps complete the job. Great looking work!
    In the wiring gutter, is the electrician running low-voltage and sensor wiring along side of the line voltage?
    Regards,
    PR
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    Paul,
    All low voltage wiring going into the wiring guide has been changed to THHN,14 gauge before going into the channel.Most of the sensors for the Tekmar are brought in from the rear.
    Our favorite electrician, Brett, has a stellar record. I fully trust him to wire anything we put in front of him. He ALSO knows who to call if any questions arise during the job.Brett is one of the few electricians that actually loves doing boiler wiring. He totally understands most of it, and always asks the right questions. He's done some huge jobs for us and hasn't missed 1 so far. My electrician....I think I'll keep him. Chris
  • Darin Cook_3
    Darin Cook_3 Member Posts: 389
    Kudos to the Milne Gang
    The install looks great. The system wiring is always the ugly part of the job in my opinion, but your wiring looks like a million bucks. The guy who usually wires our systems I am ready to let go. A professional install ( as if you guys do anything else ).
    Darin
  • George Carey
    George Carey Member Posts: 13
    Scott,
    The tekmar control (262) looks like a Rose between two Thorns :)
    George
  • Mark Hunt
  • Nice work
    And I really like how you found space to mount all the wiring controls where there was no space . That 262 looks familiar - we installed our 1st one today .
    I also like the sturdiness of the black steel manifolds on the wall . Who makes those ball valve-drain combos ?
    Scott , you have a great duo installing your boilers , and a 1st rate electrician .
  • J.C.A._3
    George, Thanks!
    If you've got time, drop me an email at jcaog@comcast.net . Great results! Chris
  • Darin Cook_3
    I have been asking myself that for about two months
    about the project you were on up north. HEHEHEHEHEHE
    Darin
  • gerry gill
    gerry gill Member Posts: 3,078
    thats-a-nicea - job!
    thats some really sweet work..the bar is raised!
    gwgillplumbingandheating.com
  • J.C.A._3
    Ron, thanks
    Those are Webstone purge setups. They come in sweat and female configurations.(they can also be had with a pump flange for Pumps on the return.BOOOO) I like em' too...one less place for a leak, they come with caps attached and they look nice to boot!
    I'm trying to get my helper on this job to be my sidekick. He shows a definate aptitude and willingness to learn heating.He asks all the right questions and questions all the answers. I think he'll be a great student and counterpart willing to learn how to do it well and pretty. Chris
  • Mark Hunt
    You mean
    the one I had to fix all of your leaks on smart a**?
    The one where I had to do all of the plumbing and HVAC since you do not know how? That project?
    HE HE HE HE HE !!!
    Try again space cadet.
    Mark H
  • joel_19
    nice
    for those of you that don't know the boiler is an RN-245 two stage i beleive . Which has two complete gas trains in it .The Rn's where replaced by the Vitogas 100 series of boilers which is now becoming like the homely sister to the Vitodens but still a fine boiler.
  • joel_19
    not trying to be too nitpicky but why use a Tekmar controll on a Viessmann? why not just use a Viessmann controll ? Sure you can put a BMW motor in a Mercedes but why would you want to? One of the best things about using a Viessmann to me is the excellent plug and play controlls , elimnates all that pesky wiring.
  • ScottMP
    Have you two
    considered getting a office to go to ??
    Maybe just get each others e-mail ??
    Scott
  • ScottMP
    I think
    The BMW has more flexabilty than the ridgid Viessmann control.
    More to the point, we use Tekmar controls more often ( very broad product line ) ands it better for the crew to know one line well, than two or three alittle bit. Make sense ?
    By the way Joel, thats a RN 280. ( And you thought you knew the line :) )
    Scott
  • ScottMP
    Here ,here...
    Yes, my thoughts also Chris. Brett is a very talented guy and has a Great Additude.
    His work for us has allways been top notch and he is one of the very few electricians who knows what we are talking about.
    More importantly, when he's done, you throw the switch and it works. First Time , Everytime !!
    Scott
  • Ted_9
    Ted_9 Member Posts: 1,718
    heating
    Excellent work as usual. You guys are a credit to the trade.
