Sparko Powertrack
John Mills_5
Member Posts: 952
Tech found a Sparko Powertrack zone system today. Needs a valve for it. Apparently they mount on a manifold and have their own controller so retrofit to a different brand wouldn't be easy.
Sparco
Aren't they still around? Perhaps bought out by Honeywell?
Found them!
I was spelling it wrong, they are Sparco. Found an online place to buy, now see if I can get parts locally.
Found them at www.plumbingworld.com0 -
They are alive & well...
Now known as Honeywell water products, and should be available from any hydronic-oriented Honeywell distributor.
The new Supervents, TRV's, zone valves, manifolds, 3 way mixers for potable and radiant plus much more. Part numbers are MZV520-RP with end switch, MZV521-RP without end switch. You don't need to drain the system to change the powerhead.0 -
This is it
Bill, what we need is a replacement for one of these valves mounted on the manifold. Is that the number you gave me? Thanks.0 -
Yessir...
Just check for an end switch, and order the appropriate product. The new valve motors are red & black. Their phone number is 401 238 4290, or go to www.customer.honeywell.com for more imfo.0 -
Thanks so much
Got one coming in at a reasonable price by Johnstone.0 -
pity they are not more readily available..
as they are the best ZV's IMHO - quiet, fast-but no hammer, easy to service, and built in flow control, and very little pipe real-estate, easy to see state they are in.
the hew honeywell 50008043 series only has:
"quiet", "fast-but no hammer", "easy to service" but only costs half as much - but when you concider tee's and labor, the "sparco-track" with the "powertrack" cant be beat0 -
The tech was thrilled
by how easy it was to change!0 -
Hi, Kal...
They should now be available from any hydronic oriented Honeywell distributor. Not all will stock them (yet) but they all can get them. If you have a problem let me know. Thanks for using our products!0
- 109 Chimneys & Flues
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
