radiator indentification
Dick Case
Member Posts: 3
I have a project with 3 types I can't Identify with the E.D.R. book....
1 type has "St. Louis Standard" markings. My notes were taken quickly, that might be "St. Louis STD." They look similar to a Rococo or Florentine. They are 3-column
The second type is unmarked and similar to the above.
The third is a small bathroom wall unit. 24x8" with a plain cast cover and 5 "slots" in the top of the face.
I have pictures of these that can be e-mailed if necessary.
Perhaps I am not looking in the right place for markings?
I'd appreciated any clues.
Close Enough
I would take one from the book that is simular to shape and size.Then you couldn't be off by more then 10 percent....0
- 87.2K THE MAIN WALL
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 75 Pipe Deterioration
- 6.4K Radiant Heating
- 15.6K Strictly Steam
