hot water recirc lines
Bob Frazier
Bob Frazier Member Posts: 4
do you ever need an expansion tank on a hot water recirc line for hot water tanks
  • Larry Weingarten
    Larry Weingarten Member Posts: 3,994
    You need to think...
    ... about the entire system. If the house/building is on a pressure reducer or backflow preventer or some other one way valve, you need a way to accommodate thermal expansion. The recirc loop itself needs no separate tank.
    Yours, Larry
  • Tim_41
    Tim_41 Member Posts: 153
    installed
    Bob, I installed one on our water heater a month ago. We have a well pump. It works great with no effects on any other part of the system. It does save a ton of water and BTU's from the Vitodens.
