hot water recirc lines
Bob Frazier
Member Posts: 4
do you ever need an expansion tank on a hot water recirc line for hot water tanks
You need to think...
... about the entire system. If the house/building is on a pressure reducer or backflow preventer or some other one way valve, you need a way to accommodate thermal expansion. The recirc loop itself needs no separate tank.
Yours, Larry0 -
installed
Bob, I installed one on our water heater a month ago. We have a well pump. It works great with no effects on any other part of the system. It does save a ton of water and BTU's from the Vitodens.0
- 167 Indoor-Air Quality
