cutting sight glass to length?
Grinding works great for eliminating the sharp edges and shortening the glass tube just a bit... :) ...or even for just cutting right through. Use the more friable but harder green silicon carbide wheel on the bench grinder rather than the pink or gray aluminum oxide, results are better. Don't breathe the dust - you get lots of it. Go outside in the wind.
It is much faster, but the glass is still breakable.
