Broomell system boiler replacement
I spoke to dan at one of his steam seminars about a customer that has a broomell vapor system, and i just want to be clear on what he told me about eliminating the reciever with the big float and drop the returns to below the water line and put big air vents on the dry returns, and run a vapor stat. Should i also put vents on the ends of the mains to quickly vent the mains? Thank You
