Insul-Tarp under radiant
Ed_26
Ed_26 Member Posts: 284
Check out www.healthyheating.com - good article on underslab insulation. also search this site - lots of info & reasearch done.
  • John T
    John T Member Posts: 6
    Does anyone have any experience with a product called Insul-Tarp. A customer is requesting we use it for an in-floor radiant basement job. We have always used 1.5 to 2 inch foam. The web site does not give an R value.
  • John T
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    Insultarp...
    has been around a while...and its ok. One nice thing it incorporates in insulation and vapor barrier in one....I still prefer the tried and true foam board. kpc
  • I looked too............
    strange that they don`t give an R-value. I wonder if its like that "bubble-wrap" stuff?
  • Rob_34
    Rob_34 Member Posts: 21
    The insultarp says that it gets an R-10 equivalent. It is conprised of the tarp with silver side facing inside, one layer of bubblewrap, and two layers of polyethelene foam with the other side of the tarp with the silver facing in. Supposedly 1/2" thick but varies.
    Rob
  • ALH_4
    ALH_4 Member Posts: 1,790
    Foil
    I am suspect of any product that uses silver facing under a slab. The silver facing may help reflect radiant energy, but there is no radiation under a slab.
    -Andrew
  • \"Equivalent\"
    I`ve heard that before, I had a guy tell me his was "equivalent" to R11, it was "Reflectix". I went on the website and right there it said R-1.1! If it`s that much better why wouldn`t they insulate the walls and attics of houses with the stuff?
  • Tom Kane
    Tom Kane Member Posts: 56
    insulation under the slab................
    try checking w/ the rpa..........they probably have info on this...
  • It is NOT an R10 equivalent, no matter what they claim.
    It is about an R 1.6 or so.
    Not worth the money.
  • actually
    they don't
  • Tom Kane
    insulation..............
    We were able to access some very useful information from them on this topic, I think if you get into their site and ask around you might be able to find it........if I remember it tomorrow I'll post it for you
  • Weezbo
    Weezbo Member Posts: 6,231
    i saw some JM 1/4 4X8 sheets of foam board...
    i would hazard a wild guess that has a higher R value.
    i wondered what was with the stuff buh i hate to be mr Guinea pig on everything that comes down the pike....:)
  • Ragu_5
    Ragu_5 Member Posts: 315
    Sales Pitch...
    We rate Insul Tarp at R .9-1.0.
    Underslab applications use 2" foam.
  • Dave_103
    Dave_103 Member Posts: 8
    Great info Ragu.............
    I don`t think this stuff is any better than "bubble-wrap", which aint much!
