24 volt zone heating
chasmanc
Member Posts: 1
I accidentally left my breaker off to my 24 volt 3 zone heating system. I was away for 2 days and when I returned my house was about 80 degrees even though the 3 thermostasts were set at 60 degrees, WHY ?
A wild guess
Thermal cycling.0 -
OR.........................
Did you turn off the right breaker?, where do you live? is the boiler itself a power pile type.....? Is there a pump on your system? did it run when you turned off the breaker? Etc... More info needed as usual. No disrespect intended, but it's like someone asking,... "I have no heat, what's the problem....;-) I had it yesterday.....
Mike T.0 -
solar heat gain?0 -
heck of a question ...were the boiler connected to a indirect
with constant circ stradgey on the DHW... think it might be matched to the heat loss at this time of year and was heating the home through the recirc system...?
leave an electric appliance stove some other heat source running during that time? the heat plates on some coffee makers Pump some heat....Kids having a party while you were gone?0 -
Gotta tell ya........
It peve's me off when someone asks a question and we all contribute to try and solve the problem and BOOM!!!!!!!!!! The guy goes on vacation or wherever!!!!!!!!!!
We need one of them things that tell you to take a number and you will be called in the order. That way when the guy doesnt answer, clear the post.
My .02 It's only Fri and I should be happy......:-)
Mike T.0 -
Bruce...
I was thinking more along the lines of a Banana peel. Wouldn't want to hurt my PC.....:-)
Mike T.0 -
Zone system
Is it possible the zone valves are power closed and were left in the open mode when the power was turned off?0 -
Another thought
Just kidding, but....Is it possible that there is about 2000 candled in the house? You know the long burning one's? WE DONT KNOW,.There is no feed back... DELETE,DELETE, DESTROY the post Carol....:-) Maybe the 2 houses nest door burned down and he is getting residual sensible heat gain??? WE DONT KNOW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Mike T. Don't hate me cause I'm beautiful........:-) My dog still licks my feet.....(YUCK)!!!
Mike T.0 -
A dog of questionable taste . . . ?0 -
Questionable taste
If his dog is like any of my dogs, feet are a step up.
A good frost = poopcicles
Larry0 -
And some folks say that a dog's mouth is the cleanest place on earth, or something like that.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
