recognize this solar collector and connector?
hot_rod
hot_rod Member Posts: 26,594
in Canada, don't know much about the history. I suspect those connectors are no longer available? Do you know the brand of this collector and fitting??
hr
    04 vintage, Western Canada installation
    looks like industrial or process piping components.
    hr
  • Metro Man
    Metro Man Member Posts: 220
    oldies..
    Worked on those b4. Love those connectors (not) . Think they used a special silicone gasket. Note the welded frames... $$$$. Big pain if you had to get into. I may even have a few out in the bone yard.
    What did these come off of?
    Metro Man
  • Metro Man
    digging
    I will have to do some digging to see if I still have the info. I want to say the collectors are old Energia's but don't think that is right. Will see if I still have the info and get back to you.
    Tossed a lot of the old collector tech manuals out a few years ago...
    Metro Man
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,010
    HR
    I'd suggest you get in touch with the good folks at www.zomeworks.com (505-242-5354) and see what they can come up with. They have been in solar since the late 60s. Steve or Dave will know.
    Yours, Larry
  • Mike Dunn_7
    Mike Dunn_7 Member Posts: 6
    fittings
    That same clamp is used on my new viessman collector fittings.
    Mike Dunn
