recognize this solar collector and connector?
hot_rod
Member Posts: 26,592
in Canada, don't know much about the history. I suspect those connectors are no longer available? Do you know the brand of this collector and fitting??
hr
hr
04 vintage, Western Canada installation
looks like industrial or process piping components.
hrBob "hot rod" Rohr
Living the hydronic dream0 -
oldies..
Worked on those b4. Love those connectors (not) . Think they used a special silicone gasket. Note the welded frames... $$$$. Big pain if you had to get into. I may even have a few out in the bone yard.
What did these come off of?
Metro Man0 -
digging
I will have to do some digging to see if I still have the info. I want to say the collectors are old Energia's but don't think that is right. Will see if I still have the info and get back to you.
Tossed a lot of the old collector tech manuals out a few years ago...
Metro Man0 -
HR
I'd suggest you get in touch with the good folks at www.zomeworks.com (505-242-5354) and see what they can come up with. They have been in solar since the late 60s. Steve or Dave will know.
Yours, Larry0 -
fittings
That same clamp is used on my new viessman collector fittings.
Mike Dunn0
