radiant
Mark Custis
Mark Custis Member Posts: 537
pray to the burst proof guy.
Only one loop?
Try a point and shot thermometer, to locate the loop. Apply lots of heat. If it is an outer edge of the building run straw bails to the building edge will help.
Good luck.
Let us know what happens.
^^^ goes off to buy glycol test strips.
  • paul_91
    paul_91 Member Posts: 62
    radiant zone
    what is the best way to defrost a frozen radiant heat zone(pex) ?
  • Mike Dunn
    Mike Dunn Member Posts: 189
    frozen zone
    Simply use the Hydronic loop defroster 2000. I believe Binford makes it.
