radiant
Mark Custis
Member Posts: 537
pray to the burst proof guy.
Only one loop?
Try a point and shot thermometer, to locate the loop. Apply lots of heat. If it is an outer edge of the building run straw bails to the building edge will help.
Good luck.
Let us know what happens.
^^^ goes off to buy glycol test strips.
Only one loop?
Good luck.
radiant zone
what is the best way to defrost a frozen radiant heat zone(pex) ?0 -
frozen zone
Simply use the Hydronic loop defroster 2000. I believe Binford makes it.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
