Flushing a steam system with TSP
You might want to contact Rhomar. They are pretty helpful.
http://www.rhomarwater.com/products/residential-steam-system/
Steam Boiler Flush With TSP
We are currently working with a steam boiler that has a lot of dirt/oils etc. We just picked up this customer. I seem to remember some wise old man talking about flushing a system with TSP (Trisodium Phosphate) Does anyone out there know the proper procedure...Squick just doesn't seem to get the dirt out on this partictular project.
Thanks in advance and Merry Christmas0 -
Squick
One cup per 100,000 BTU input for the TSP. Squick can crack your boiler do not use it.0 -
Dan's Big Book (Lost Art of Steam Heating) goes into a ton of detail on cleaning procedures -- both those recommending by boiler making companies and his own.
I'm no expert but there are some real pros and cons it seems with all of the methods, and some tricky issues when using chemicals. Mostly how to remove the chemicals from the boiler and the downsides of letting any chemicals go up into the building pipes (basically the chemicals will "clean" the pipes but this could cause more trouble than its worth).
Not saying not to use them -- and i'm a complete amateur so don't put too much stock in what i say. But after reading dan's books and the boiler manual -- i decided it just wasn't worth the risk of using chemicals since i wasn't confident i wouldn't do more harm than good.0 -
cleaning boiler
do a search here[button on orange banner above]-key word "skimming", which is the term for the correct way to clean a steam boiler. about the only chemical i have used is arm & hammer washing soda [recommended by peerless boiler] 4 lb. per 1,000,000 btu. squick will not be a substitute for this. the web site of the boiler mfg. may also have instructions on this.
dan's book goes into this in some detail, and i can see you will benefit from it.--nbc0 -
A lot depends
on the type of boiler you have. If it uses rubber-like seals between the sections, do NOT use any type of chemical as it may rot out the seals.
If it has steel push nipples between the sections, it's far more forgiving in that regard. But I still would avoid chemicals in favor of flushing the boiler out with a hose, then skimming it.
A 4 hour skim session will do you good. By a pro of course.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
