Recommendation on an automatic feeder
nicholas bonham-carter
Member Posts: 8,577
we are honored to have someone of your famous name visit us here!!
i believe that steam heating originated in france. alas they did not persevere as we did here--i wonder why?
are you sure that your system is not "too thirsty"?
as you investigate the auto filler solution,why not also make sure that you are not losing water somewhere?--nbc
automatic feeder recommendation
May I ask for the uncommon wisdom of any of you that might recommend an install it and more or less forget it automatic feeder for my steam boiler? The cheapskate owner who rented the house that I bought before me did not put one in and the regular visits to add water are getting a little tiresome. Thanks so much!0 -
Apologies for not noticing a very similar topic where the Hydrolevel VXT feeder was recommended. Are there any mechanical models that are tried and true or are the new-fangled digital ones really the way to go?0 -
if you do put on an automatic feeder --i would add a water meter to monitor your water usage and spot a problem before it becomes a REAL big prob..--there are no feeders for steam boilers that are install and forget --you still need to flush and test periodically --flush and test the mechanicals and clean the probe and test -probe style --0 -
Is there anyone with "Dead Man" knowledge in the Trenton/Princeton area floating around? I think I would like to combine this installation with an examination of my system in all of its non-glory.0 -
hah .... a dubious honor indeed
We are definitely leaking some water through faulty vents so I am going to take care of that first. I can't fit Gorton vents in the tight quarters that are filled by the vertically mounted cylindrical types. Does anyone know if one can use some kind of flexible extender which would allow me to screw the vent in away form the radiator and then move it back to a vertical position?0 -
Nicholas..
don't go losing your head now, over this gentleman.
(heads "rof...") 0 -
the chicken or the egg?
which comes first, the vent going bad, or the problem causing it?
i suspect you have either over pressure [above 16 ounces, or a boiler piping problem causing too much water to be drawn up into the pipes, instead of staying in the boiler.
certainly try some new good quality gorton or hoffman vents. then see if the problem has been solved.
if not come back here for more jocular advice!--nbc0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
