power vent vs chimney liner
Pinball
Member Posts: 249
Personally, I've never seen a motor/blower fail on a conventional chimney. It's not a matter of WILL it fail. BUT WHEN?...probably @ 2am when it's 10*below on christmas eve!
Just be sure to provide enough fresh combustion air to the mechanical room for all the appliances. Reguardless of which one you use.
I am replacing an oil fired steam boiler with a gas fired steam boiler. The contractors tell me that if I use the existing chimney I need a liner. Instead of the chimney liner I can use a power vent model.
The existing chimney has an atmospheric gas steam boiler and two water heaters in addition to the existing oil fired boiler. So there are 4 appliances using one chimney. Inside dimensions of the unlined brick chimney is 8 inches by 8 inches.
What would you folks recommend for a venting option on the replacement boiler power vent or chimney and the reasons why?
If I go with the chimney liner, what type of liner do you recommend? Aluminum, stainless steel or AL29-4C?
Thank you in advance for your advice.
liner etc
I would line with stainless and I would install a oil boiler with a gas power burner. Better equipment, could get it with domestic coil and it allows a easy conversion back to oil if you choose.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
