Burner fired the shut off???
Casinojunkie
Member Posts: 36
My old American Standard boiler has a converted burner from coal to natural gas.
Went to the basement tonight and the burner was burning.
It burned for just a little while, did not make steam,
then shut off.
What are some of the things that would cause this.
Not very efficient, right!!!
then shut off.
Several possibilities, none of which a HO should be dealing with. THIS is a job for a pro. You are only paying with your $$$ for the gas now, but could end up paying with your life.
Tim
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Just a guy running some pipes.0 -
Might also be
running to make hot water and shutting off on a sub-steam aquastat. As Tim said though, if this seems unusual, call a pro and pronto.0
- 167 Indoor-Air Quality
