water flow meter
Perry_2
Perry_2 Member Posts: 380
I just priced 1" flow meter (1" T that can be soldered to Copper), digital, power supply not included (needs 24 V power supply).
Nice unit; can handle dirty and hot water.
A mere $1066 + shipping.
If you are only measuring clean cold water, you can probably get a rotometer for $30 - $50. It does have to be installed inline though.
Perry
  • Dale
    Dale Member Posts: 1,317
    Flow meter source needed
    I'm looking for a 3/4 inch flow meter,( digital would be nice but not necessary), to use to show flow through a 190K input on demand Takagi water heater. I'm going to try to demo flow, gas pressure and outlet temp. If anyone can point me to a water flow meter they use I would much appreciate it.
  • ALH_4
    ALH_4 Member Posts: 1,790
    Letro
    Pentair/Letro has some nice rotometers.
    -Andrew
  • Doug_7
    Doug_7 Member Posts: 266
    Water Meter
    See WM Series at: http://assuredautomation.com/flow/index.php
    Totalizer for metering cold domestic water.
    Regular meter is $105 and with pulsed output is $160.
