Ford E450
Mitch_6
Mitch_6 Member Posts: 549
Was looking at the L45 but found it to be to much truck.
I am now planning on a E450 diesel with a twelve foot long dropped box.
Any luck good or bad
Mitch S.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=388&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • John@Reliable_12
    John@Reliable_12 Member Posts: 24
    Mitch.............
    I don't have a 450 but do have a E350 diesel. Great truck but hard on brakes and front ends but will pull a house down with its power. Next to impossible to work on under the hood,have had fuel leaks in that area. I also have a Isuzu cab over box truck which I think is eazier to drive around town and is alot like the L45.Depending on what you do,ie: service,installs,heat,a/c,plumbing all of the above I don't think you can ever have enough truck(room). Plus I also like the cab space not part of the rolling warehouse.
  • joel_19
    joel_19 Member Posts: 933
    Why buy one of those when you can get a Mitsubishi cab over? Or if you want something a little smaller get a Sprinter 20MPG do the math.
  • T. J._2
    T. J._2 Member Posts: 2
    Ford E450
    If you want versatility in a smaller package, you really can't beat the Dodge (i.e., Mercedes) Sprinter. But for power, its 2.7L turbo-diesel isn't even in the same ballpark as Ford's torquemonster Navistar 6L turbo-diesel in the 450.
    There's no replacement for displacement.
