WARM AIR FURNACE QUESTION
PLUMBARIS
PLUMBARIS Member Posts: 22
As for combustion products that depends if we're talking 90% sealed combustion or not. Also your blower door safty switch has been disabled, probably half of them in the country are. And it sounds like your return air is seriously undersized.
  • Mark_82
    Mark_82 Member Posts: 11
    WARM AIR FURNACE BLOWER QUESTION
    Hello all--I was changing the air filter on my Warm air FURNACE=While the blower cover was off the the burner came on-and a few minutes later the blower come on--The amount of heat that was blowing from the vents in the house was unbelievable-the house heated quick! I have a ranch home with 7 rooms and a finished basement where the burner is..
    My question is--Why couldnt i keep that blower cover off and replace it with a air filter? The volume of air flow was insane--and the heat was as hot as if the cover was on.. Thanks for any answers.. Happy Holidays!!! MARK
  • tim_20
    tim_20 Member Posts: 41
    furnace door
    In no way should the furnace door be left off as the products of combustion could be pulled back into the blower creating a very unsafe condition. check your duct sizing and was the filter clean?
    T.Y.
  • walnuts
    walnuts Member Posts: 21
    sounds like you are seriously lacking return air. What size furnace(btu's), and what size ductwork(supply and return)?
  • mtfallsmikey
    mtfallsmikey Member Posts: 765
    Returns
    The 50% statement applies to cold air returns as well
  • Don't forget about the atmospheric vented water heater sitting next to it
