Gorton vs. maid o mist
mike jones
mike jones Member Posts: 32
how many radiators in a home
  • shawn_11
    shawn_11 Member Posts: 24
    looking for a comparison
    One pipe steam radiator vents:
    both the Gorton D and the Jacobus/Maid O' Mist D are advertised as having the "venting capacity of 27 air valves." However Gorton is twice as expensive.
    Are they really comparable?
  • bob young
    bob young Member Posts: 2,177
    jacobus
    i have used jacobus for over forty years and never had a problem. the price has always been right for frugal customers. interchangeable size orifaces can also be helpful when balancing systems. on mains GORTON is king. an oldtimer [ older than me !! ] once told me jacobus & gorton were once partners.
  • Mike Cascio
    Mike Cascio Member Posts: 143
    The difference between the Gorton's and the Maid O Mist is that the Gorton has it's insides made out of brass. The Maid O Mist's insides are made out of plastic.
    Michael J. Cascio
  • mike jones
  • soot_seeker_2
    soot_seeker_2 Member Posts: 228
    You will find...
    ...that you get what you pay for.
    I don't think this is the place to save money if you are only buying 10 or 20 valves.
    And yes, the Gorton valves have a beautifully machined brass float in them and are soldered together. The Gorton's temperature sensor is made by Texas Instrument.
    Maid-O'-Mist uses a plastic float and the case is crimped together.
    They both share patents and are of similar design.
    Long Beach Ed
  • gerry gill
    gerry gill Member Posts: 3,084
    i'm a Gorton man
    buy lots of them..haven't had a bad one yet..
    gwgillplumbingandheating.com
  • Rodney Summers
    Rodney Summers Member Posts: 748
    C'mon!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    nolo contendre.......GORTON. MAD DOG
  • Timco
    Timco Member Posts: 3,040
    What about Hoffman? I bought 3 #1A vents the other day and one had a pin hole defect in the bottom and blew steam & water. Was not sealed...they gave me some sight glass bushings for free for the inconvenience...
    Tim
    Just a guy running some pipes.
  • Tim_64
    Tim_64 Member Posts: 76
    I learned
    when I took apart a maid-o-mist... That particular vent only worked a few days in my system..
    Anyway the float thing was cheap crumbly plastic...
    Never again will I buy the Home Despot crap...
    Gorton
  • kpc_45
    kpc_45 Member Posts: 29
    it would be like
    a Yugo to a Toyota.
  • GORTon the silver screen
    on 12 dec, there will be an appearance of GORT on the silver sceen with the release of the remake of "THE DAY THE EARTH STOOD STILL"
    do i remember radiators in the space ship in the original [1956?]
    yet another reason to choose your vents wisely!--nbc
  • V8toilet
    V8toilet Member Posts: 71
    I've had the same Maid-O-Mist valves on my system for over two years now without any problems.
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,430
    It was a cold and stormy night and I was over the girlfriends house. No parts at hand and the heat was just turned on that day for the heating season. One vent after the other was not working either stuck open or closed. In a fit of anger I went to the big orange den of inequity and bought a dozen maid of mists just to get me through the weekend. Odd thing happened they all worked fine and are 2 years old and still doing fine. I would not buy them for a paying customer but they worked this time. If I had to put my name on the job I would go with Gorton or Hoffman.
    cell # 413-841-6726
