Ouch!
Tony Shupenko
Member Posts: 54
The copper pipes goes into a hallway, then up to the illegal (oops, undocumented) apartment in the attic. I guess this was cut in when the owner wanted to get some extra $$$ by renting out the attic (circa 1920's 2-family box-shaped home in older sections of northern N).
The copper pipe in the hallway is also un-insulated.
I know that the hallway pipe should be insulated, but what about this little section?
Regards,
Tony
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=404&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Regards,
Tony
Ouch!
I saw the attached at a home. Any thoughts on this - should this pipe be insulated (living room location - overall length of pipe is about 16", including all fittings)? Location is a living room.
Regards,
Tony
PS - Nice wood cover for the radiator
Where to begin...................
About the only good thing from that photo was the handle wasn't broken0 -
Bull headed tee and copper at that. Looks like someone added a radiator on the right.
Can't be pitched right.
ED0 -
Insulation is
a great way to cover it up. Can the responsible parties be found, if living?
can't get
Can't get the picture on my sidekick.... Must be bad as others are saying..0 -
Insulation is a moot point. After all, that tube/pipe is providing its heat to the conditioned space.
The real problem is the arrangement. Assuming there's another radiator to the right, if either or both are under- or over-performing, there's no solution save proper design and piping. TRVs on both radiators might help, but such is really pushing the limits...0 -
Unless that hallway is frequently open to the outdoors via an open door, insulating the pipe probably won't do much...
What's the real problem?0 -
I am concerned about burn protection - I do home inspections and noticed toys very close to the pipe (I moved them for the photo), indicating that small children play there.
They'll only need to touch it once, to learn never to touch it again.
That's how we learned.
The radiator is right next to the pipe, and it is the same temperature.
COVER
If thats what this is about , box it in , maybe it will look like its supposed to be like that
- 167 Indoor-Air Quality
