Type of sealant
mtfallsmikey
Member Posts: 765
For that particular purpose: A piece of Kaowool blanket.
Type of sealant
On a weil McLain 368st oil fired boiler, what do they use to seal the burner housing to the boiler? Thanks tom0 -
TRY STANDARD HERCULES FURNACE CEMENT
sealent
your oil company can get you the proper gasket it is similar to paper but is not paper0 -
type of sealant
The fire box was replaced and sealer in the box was like a putty, but it was hard, what else can i use. tom0 -
the 66/68 series chamber kits come with what looks like brown putty in 1/4 inch strips ---we call it dogsh%^ i use a 1/4 ceramic silica rope found in any good heating supply house --and either use a spray adhesive or a high temp silicone to hold it in the sealing groove0 -
sealant
Thanks for the info Tom0 -
Sealant
Does someone know where i can get,1/4 ceramic silica rope, i tried sidharvey don,t have tried a plumbing house in springfield mass don,t have.0 -
Sealant
-its high temperature rope gasket --tell them what you are using it for and they should know or tell them you are looking for , SSC brand part #HTR 470A--1/4" high temp rope 10ft./// honestly if they don't know they are not a heating supply house , maybe they don't like to deal with the general public0 -
Try
Try FW Webb, lock your car. Not one of the nicer parts of Spfld.0
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
