Type of sealant
For that particular purpose: A piece of Kaowool blanket.
  • Diciocco
    Diciocco Member Posts: 27
    Type of sealant
    On a weil McLain 368st oil fired boiler, what do they use to seal the burner housing to the boiler? Thanks tom
  • bob young
    bob young Member Posts: 2,177
    TRY STANDARD HERCULES FURNACE CEMENT
  • ed wallace
    ed wallace Member Posts: 1,612
    sealent
    your oil company can get you the proper gasket it is similar to paper but is not paper
  • Diciocco
    type of sealant
    The fire box was replaced and sealer in the box was like a putty, but it was hard, what else can i use. tom
  • oil-2-4-6-gas
    oil-2-4-6-gas Member Posts: 641
    the 66/68 series chamber kits come with what looks like brown putty in 1/4 inch strips ---we call it dogsh%^ i use a 1/4 ceramic silica rope found in any good heating supply house --and either use a spray adhesive or a high temp silicone to hold it in the sealing groove
  • Diciocco
    sealant
    Thanks for the info Tom
  • Diciocco
    Sealant
    Does someone know where i can get,1/4 ceramic silica rope, i tried sidharvey don,t have tried a plumbing house in springfield mass don,t have.
  • Diciocco
    Sealant
  • oil-2-4-6-gas
    -its high temperature rope gasket --tell them what you are using it for and they should know or tell them you are looking for , SSC brand part #HTR 470A--1/4" high temp rope 10ft./// honestly if they don't know they are not a heating supply house , maybe they don't like to deal with the general public
  • Hvacman
    Hvacman Member Posts: 159
    Try
    Try FW Webb, lock your car. Not one of the nicer parts of Spfld.
