safety for installing solar collectors on a pitched roof
jon_22
jon_22 Member Posts: 2
ross get safety harness and roof anchor half inch dia rope and a rope grap and you will be good to go
  • Ross Goldstein
    Ross Goldstein Member Posts: 7
    how to make a pitched roof solar hot water job safe
    I am bidding a job with 3 flat plate collectors to go on a 45 degree pitched roof. We normally do flat roof jobs, so how can I make it safe -when there is no place to tie a harness to to set and pipe the collectors.
    hot_rod Member Posts: 26,594
    Texas Hold Um
    google Reeves Texas Hold Um. Plenty of other brands, possibly rent one to try.
    hr
  • Ross Goldstein
    Thank you for the advice
    I wanted to thank you for the advice
    Ross
