BG or Taco?
GW
Member Posts: 5,137
Hello,
I have a little commercial job, there are apartments right over the boiler room. They want a new 1/4 horse boiler pump installed, my question is which is likely to be quieter, a Taco 122 or a BG 2 1/2" Booster? Thanks for any comments, I told the maintenance guy I would check into it.
gary
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=368&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
gary
taco 1600 pump
May I suggest the Taco 1600 pump with a 1/4hp resilient mounted motor? One of the attributes of the Taco 1600 series is the resilient rings which isolate any motor vibration from resonating throughout the piping. FYI; Taco offers the 1600, and 1900 series pumps that are hydraulically the same, but the 1900 series is a true close coupled design, and the 1600 series resilient mounted, which makes it a better candidate for applications where noise may be an issue. Please visit the Taco web site at www.taco-hvac.com for more information on these two horizontal inline pumps. For your convenience I attached the catalog data.
Joe Mattiello
Technical Support Technician
Tel. 401-942-8000 X 484
Fax. 401-942-2360
1160 Cranston St
Cranston, RI 02920
joemat@taco-hvac.com0 -
I agree with Joe
Taco 1600, I have installed more of these than I can count and never a problem! Also easy to fix!0 -
Little commercial job
With Apt's. over the boiler room. Im I missing something? How big is this building and what size is the boiler, longest run? The 1600 pump can do alot, but for small commercial?
Mike T.0
- 167 Indoor-Air Quality
