O. A. Smith water heater
Rich W
Rich W Member Posts: 175
Still having trouble? How long has this unit been in place? Is the WH on it's own circuit? It should be.Is it plugged into a GFCI? It should not be. What is the uA reading? Have you seen any other codes before the lock out (6) code?
