What is your pleasure
to think about. Thanks again for the input, I will let you know what I decide.
HVACTV people have asked me to
do another series on their last Tuesday night of the month show.
What would you like to see?
I have already done:
Thermocouples
Electric Ignition Systems
Carbon Monoxide
What other gas related subjects would you be interested in?0 -
Hi YA Tim
How about gas valves ?
Go Tim!
I second the motion for gas valves! A second idea would be pressure regulators (springs, adjustments, etc.)0 -
Hi Timmie...hows about..........................................
Rehabbing sooted up gas boilers and when its time to replace. I do a lot of these and there always comes the moment when you know its not going to be cost-effective. Mad Dog
Combustion analyzing.
Dave in DenverThere was an error rendering this rich post.
review of test units
with diffrent manufacturers of test units who has the best head to head in analizers? I would be intrested in the cost comparison also.
where will my money be best spent on new technology units?
Thanks Terry0 -
Dave Stroman
I did a complete series on Combustion Testing and it is archived on HVACTV.com under the Best of Tim McElwain.
Maybe at some time Ric can get some folks from Bacharach and Testo along with Jim Davis for a session.0 -
Terry,
> where
> units? Thanks Terry
Terry,
> where
> units? Thanks Terry
Terry,
It would probably be a good idea to have Testo present and then Bacharach and comparison can be made after hearing from both companies.
I am not sure who to contact from TSI but they should also have something to say.
I am not really qualified to discuss the pros and cons of testers. I use both Testo and Bacharach and find that the differences off set one another.0 -
ideas
Well Tim, I think a review of gas pressure testing would be worthwhile, I'm seeing alot of problems with instantaneous water heaters and a review of how and where to put the gauges would help. What's expected from the utility or propane supplier and where to check that. Then what pressure drop is designed ( from the pipe size) and how to check at the appliance. If 2# nat gas and maxitrol regulators were included that would be a pretty full session. I don't know if you did the range of HW smart valve applications and tests but that's certainly a useful topic. Have fun with this!0 -
Thanks for the
input I will see what I can do.0 -
Honeywell Smart Gas Valves..
just a thought...
ME0 -
Venting
I don't think enough can be said to explain gas venting.
David0 -
Tim, I have searched HVACTV.com for your combustion analyzsis series but can not find it. Do you know where I should be looking?
I like the idea of Honeywell
Smart valves. Although I wish they never existed!0 -
Never mind, I found it. Watching it right now.
Adjusting Mod- con appliances
seem more and more of these use the same Honeywell gas valves. Be nice to get more info on adjusting procedure how and whys.
hot rod
(smart valves) not so
Bob S. I concur. I call that valve "the dum valve"
It looks like
we will be going with SmartValve.
The program will be on HVACTV.com on Tuesday night April 25 at 8:00 PM see ya there.0 -
BRAVO!
I'll tell my help to check in, and I've entered it into my PDA so's I don't forget.
Thanks for all you do Tim.
ME0 -
SmartValve presentation
It will probably end up being four (4) seperate sessions.
The first will be SmartValve Operation
2. Generation I and II Troubleshooting
3. SmartValve on a FWA System with a Electronic Fan Timer
4. SmartValve on a FHW system with a Control Center
Look forward to seeing everyone there.0
