What is your pleasure
to think about. Thanks again for the input, I will let you know what I decide.
  • HVACTV people have asked me to
    do another series on their last Tuesday night of the month show.
    What would you like to see?
    I have already done:
    Thermocouples
    Electric Ignition Systems
    Carbon Monoxide
    What other gas related subjects would you be interested in?
  • Go Tim!
    I second the motion for gas valves! A second idea would be pressure regulators (springs, adjustments, etc.)
  • Mad Dog_2
    Mad Dog_2 Posts: 8,724
    Hi Timmie...hows about..........................................
    Rehabbing sooted up gas boilers and when its time to replace. I do a lot of these and there always comes the moment when you know its not going to be cost-effective. Mad Dog
  • Combustion analyzing.
    Dave in Denver
  • Terry_14
    Terry_14 Posts: 209
    review of test units
    with diffrent manufacturers of test units who has the best head to head in analizers? I would be intrested in the cost comparison also.
    where will my money be best spent on new technology units?
    Thanks Terry
  • Dave Stroman
    I did a complete series on Combustion Testing and it is archived on HVACTV.com under the Best of Tim McElwain.
    Maybe at some time Ric can get some folks from Bacharach and Testo along with Jim Davis for a session.
  • Terry,
    > where
    > units? Thanks Terry
  • Terry,
    > where
    > units? Thanks Terry
  • Terry,
    It would probably be a good idea to have Testo present and then Bacharach and comparison can be made after hearing from both companies.
    I am not sure who to contact from TSI but they should also have something to say.
    I am not really qualified to discuss the pros and cons of testers. I use both Testo and Bacharach and find that the differences off set one another.
  • Dale
    Dale Posts: 1,317
    ideas
    Well Tim, I think a review of gas pressure testing would be worthwhile, I'm seeing alot of problems with instantaneous water heaters and a review of how and where to put the gauges would help. What's expected from the utility or propane supplier and where to check that. Then what pressure drop is designed ( from the pipe size) and how to check at the appliance. If 2# nat gas and maxitrol regulators were included that would be a pretty full session. I don't know if you did the range of HW smart valve applications and tests but that's certainly a useful topic. Have fun with this!
  • Thanks for the
    input I will see what I can do.
  • [Deleted User]
    [Deleted User] Posts: 1,160
    Honeywell Smart Gas Valves..
    just a thought...
    ME
  • David_5
    David_5 Posts: 250
    Venting
    I don't think enough can be said to explain gas venting.
    David
  • Tim, I have searched HVACTV.com for your combustion analyzsis series but can not find it. Do you know where I should be looking?
    Dave in Denver
  • Bob Sweet
    Bob Sweet Posts: 540
    I like the idea of Honeywell
    Smart valves. Although I wish they never existed!
  • Never mind, I found it. Watching it right now.
    Dave in Denver
  • hr
    hr Posts: 6,106
    Adjusting Mod- con appliances
    seem more and more of these use the same Honeywell gas valves. Be nice to get more info on adjusting procedure how and whys.
    hot rod
  • hvac-tech
    hvac-tech Posts: 36
    (smart valves) not so
    Bob S. I concur. I call that valve "the dum valve"
  • It looks like
    we will be going with SmartValve.
    The program will be on HVACTV.com on Tuesday night April 25 at 8:00 PM see ya there.
  • [Deleted User]
    BRAVO!
    I'll tell my help to check in, and I've entered it into my PDA so's I don't forget.
    Thanks for all you do Tim.
    ME
  • SmartValve presentation
    It will probably end up being four (4) seperate sessions.
    The first will be SmartValve Operation
    2. Generation I and II Troubleshooting
    3. SmartValve on a FWA System with a Electronic Fan Timer
    4. SmartValve on a FHW system with a Control Center
    Look forward to seeing everyone there.
