Small width handtrucks ?
Cosmo_3
Member Posts: 845
I had the same problem, the solution I had was simple....
Buy the hand truck you want, or your existing truck and take it to a steel fab shop. For 100 bucks they made 2 cuts down the middle and welded it back together. Works great but I still want a regular truck because the wider width when there is room for it actually helps keep the load from tipping over more than you realize!!!
Cosmo
Cosmo
Anyone know
where to look for boiler weight capacity handtrucks smaller in width than the standard 24 inches ? We use the heavy duty style with the extra wheels that glide up the stairs ( I forget the brand name ) . We're working in homes more and more often with doorways that are smaller than the handtruck can fit through .
Thanks in advance , Ron .0 -
Got a Porta Band?
although it will probably void the warranty.... it may be the best way to get the exact dimension you desire.
I'd take the Cosmo route also
hot rod
I don't think
I'd have the heart to cut a working handtruck in 2
We used to have a small aluminum handtruck with the stair wheels , but it didn't have the lean bar wheels that come on the larger handtruck . Thanks for the ideas Cosmo and Hot Rod . Would you guys happen to know any handtruck manufacturers ?0 -
Shop locally
I remember a lift truck company in Salt Lake that would build custom hand trucks. You could select frame type and material, wheel type, tie down types, stair walkers, etc.
I don't remember different widths however.
You might look into hand trucks used for O2 and actylene tanks at a welding supply shop. These seem to be pretty narrow.
I still think you are headed for a custom built one
All the components are in the Graingers catalog or Northern Tool.com
Gather the pieces you like and drop by a local welding shop with a drawing.
Google hand trucks for a boatload of info also.
hot rod
- 167 Indoor-Air Quality
