Big Taco pump, customer wants B&G
GW
GW Member Posts: 4,695
Guys, I have a appt building with a Taco 122 A2 N10. It's 11 1/8" flange to flange. It's got a 1/4 horse motor. It has 6" diameter 4-bolt flanges.
Can anyone give me an idea what this might be in B&G?
Gary Wilson
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=368&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Gary Wilson
Wilson Services, Inc
Northampton, MA
gary@wilsonph.com
  • Empire_2
    Empire_2 Member Posts: 2,343
    Gary
    > flanges.
    > might be in B&G?
    > Gary Wilson
    > _A
    > 368&Step=30"_To Learn More About This
    > "Find A Professional"_/A_
    The #'s given, the 121 comes up with a spec sheet, and this pump will deliverjust over 100GPM @ 4 ft head. Taco has the info.
  • Empire_2
    Gary
    The #'s given, the 121 comes up with a spec sheet, and this pump will deliver just over 100GPM @ 4 ft head. Taco has the info. Checked B&G, found an LD3 in line pump that is virtually identical. Offers slightly more head on the lo side, but close. Check it out. (Taco-hvac.com/ and bellgossett.com. What size is the connecting pipe? I'm not so worried about the flange configuration.
    Hope this was helpful.
    Mike T.
  • John White
    John White Member Posts: 120
    why
    Why don't we start by asking why the customer wants a B&G?
  • Empire_2
    I agree
    I do not have a problem with either manufacturer. But, you know how customers can get. SOmetimes they have their minds set on something ;-)
    Mike T.
  • Joe Mattiello_2
    Joe Mattiello_2 Member Posts: 94
    Do we know the flow, and head required?
    My thought is replacing the Taco 122 pump with a smaller less expensive pump if we know what the load is. switching to a B&G with more capacity will cost the customer more money to operate and may cause velocity issues. Just a thought.
    Joe Mattiello
    Technical Support Technician
    Tel. 401-942-8000 X 484
    Fax. 401-942-2360
    1160 Cranston St
    Cranston, RI 02920
    joemat@taco-hvac.com
