Big Taco pump, customer wants B&G
GW
Member Posts: 4,693
Guys, I have a appt building with a Taco 122 A2 N10. It's 11 1/8" flange to flange. It's got a 1/4 horse motor. It has 6" diameter 4-bolt flanges.
Can anyone give me an idea what this might be in B&G?
Gary Wilson
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=368&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Gary Wilson
Gary
> flanges.
> might be in B&G?
> Gary Wilson
> _A
> 368&Step=30"_To Learn More About This
> "Find A Professional"_/A_
The #'s given, the 121 comes up with a spec sheet, and this pump will deliverjust over 100GPM @ 4 ft head. Taco has the info.0 -
Gary
The #'s given, the 121 comes up with a spec sheet, and this pump will deliver just over 100GPM @ 4 ft head. Taco has the info. Checked B&G, found an LD3 in line pump that is virtually identical. Offers slightly more head on the lo side, but close. Check it out. (Taco-hvac.com/ and bellgossett.com. What size is the connecting pipe? I'm not so worried about the flange configuration.
Hope this was helpful.
Mike T.0 -
why
Why don't we start by asking why the customer wants a B&G?0 -
I agree
I do not have a problem with either manufacturer. But, you know how customers can get. SOmetimes they have their minds set on something ;-)
Mike T.0 -
Do we know the flow, and head required?
My thought is replacing the Taco 122 pump with a smaller less expensive pump if we know what the load is. switching to a B&G with more capacity will cost the customer more money to operate and may cause velocity issues. Just a thought.
Joe Mattiello
Technical Support Technician
Tel. 401-942-8000 X 484
Fax. 401-942-2360
1160 Cranston St
Cranston, RI 02920
joemat@taco-hvac.com0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
