Safety Glasses
Terry H.
Member Posts: 73
3M makes a great product, check out: http://products3.3m.com/catalog/us/en001/safety/occ_health_safety/node_GST29W6QVWgs/root_GST1T4S9TCgv/vroot_5SDD44F7DZge/bgel_GSTBF8Q0ZXbl/gvel_4PV4LH4X9Kgl/theme_us_ohes_3_0/command_AbcPageHandler/output_html
Almost had an accident
with a sawzall today. The reason was foggy safety glasses. I was cutting register openings in a ceiling, so I was wearing both a dust mask and safety glasses. However...if you wear a dust mask when you breath out it blows my breath up into the glasses, fogging them up. Does anyone have a better way to protect yourself?? WW
Saftey glasses
Been in that situation, go with a pair of tight fitting swim goggle like saftey glasses ANSI certified of course. Or you could hold your breath.
Gordy0 -
Dust
Use a dust mask with a valve in them. I wear glasses all the time and regular dust masks cause fogging. They cost a little more than the plain ones.
Joe0 -
That's what the help is for...
but seriously, I too like the masks that have a foam rubber contour attachment that makes a better seal, and also has an exhaust valve. I think they are a few bucks a pop, compared to a buck each or so for the cheapie ones.
Cosmo Valavanis
Dependable P.H.C. Inc.0 -
Wayne
Doesn't the dust mask have a valve on the bottom? Or as I assume you were using the pinch-nose dental office/doctor type? I use a rubber OSHA type with side filters and a bottom flap exhaust valve. Still cumbersome.
Best part is when you talk when wearing it:
"Luke..... I...am.....your Father!"
Steady there, buddy.0 -
Brad
Don't bogart that pipe dope.
Ya know, Scott
dyslexia is a terrible thing
Have not touched any drug since high school curiosity days, so either the effects are long lasting or I am just naturally goofy!
Yup, that's it. Light of heart and will live long for it.
Thanks for keeping me straight and flying right, pal!0 -
Dust masks
They are for the most part useless. The air gaps draw and exhaust more and more air as the mask begins to plug, as seen in your situation. I use a single cartridge respirator which I might add always draws in thru the filter and exhausts out the bottom check valve. They have become more inexpensive.
Mike T. PS they are lighter to.0 -
surplus
Gas mask Great for tearing down plaster lath walls & stinkey dipers0 -
Gotta agree
with the respirator idea - the white masks are useless. The last I remember I think the a Norton respirator cost about $30 plus another few bucks for the cartriges. Another thing you might try is rain-x (for car windshields) on your glasses. Never tried it but I've heard it works. The tight-fitting goggles will also fog if you are sweating, at least mine do but they don't have ventilation holes.0 -
3M makes a really nice full face respirator, you can put any filters on that you want. The respirator has the exhaust valve and a seperate mouth/nose piece to keep from fogging.
Here's a link http://www.allergybegone.com/allergybegone/3mfulfac68ga.html but you should be able to find them locally.
Hope this helps
Terry H.0 -
I've never tried this one, but now that I think of it it's crazy enough to work! WHen I ride my dirtbike I buy 'no fog cloth' made by Scott goggles it eliminates fog on goggles, which are made of lexan. I think that the average pair of saftey glasses of the same material. might be worth a shot. available at any local dirtbike shop0 -
Home Depot
Enough said. 29.99 filters a-little extra, but it's worth it.0
- 120 Geothermal
