short cycle
Danny_7
Member Posts: 5
Hello
I have a one pipe steam system. The boiler has been short cycling. I have replaced the thermostat then the thermocoupler and now have cleaned the pigtail. Any help on my next step? Thanks Danny
Short cycle
Please explain what it is doing to make you think its short cycling, give us more info on the system, gas oil, radiation in the house, all original some been rmoved, boiler make model etc.0 -
response
Bruce,
The boiler comes on when the thermostat asks for it. it comes on for about 30 seconds, shuts down for about 30 seconds, and then continues in that cycle. thanks in advance, danny0 -
Is
the water in the sight glass bouncing a lot?0 -
i think Bruce is hinting at a dirty boiler..
me thinks he's right ;-)
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"gwgillplumbingandheating.com
response
I have used steam clean in the begining of the season and the water runs clear and I drain every week. Thanks Danny0 -
But how much bounce in the sight glass??
responce
Bruce
I would guess it bounces about 1 1/2 inches. I read about this bounce problem in narrow boilers is this what you think. Thanks Danny0 -
new responce
Hello
Because you are talking about bounce I bypassed the low water shut off as an experiment. It seems to work. What are your opinions about adding a surge column at the cut off switch? Thanks Danny0 -
advice
You need to call a pro!!!0 -
Steve's right
time to have a pro look at this. Go to the Find a Professional page of this site to locate one near you. If you're in the Baltimore area, contact me.
- 167 Indoor-Air Quality
