hot water on the left, Why?
I figured it was cause if most people wipe with their right hand they want to turn on the hot water with their clean hand. Sorry to be so graffic
  • justme
    justme Member Posts: 5
    Hot water on left, Why?
    Just a bit of trivia. This is a Test.. Why is the Hot water on the Left and the Cold water on the Right?
  • Weezbo
    Weezbo Member Posts: 6,231
    because \"if you dont want the boss to leave Hot.....
    you best remember its Right Cold Outside!" Thats my quote and i am stickin toit.*~/:) or if he Left Hot ,Your Freezing ,Right?
  • rick in Alaska
    rick in Alaska Member Posts: 1,522
    Hot on Left
    When water was first used in the home, it was by the use of a hand pump mounted on the sink. It was usually mounted on the right side of the sink because most people are right handed and it is easier to use the pump with your strong hand. Since the pump was on the right side of the sink, the best place to put the hot water faucet was on the left side.
    Thats the way I've heard it anyway.
    Rick in Alaska
