Duct work code question
Tim_24
Member Posts: 53
Mechanical Code. This will list the standards, as references, that apply. Duct construction and materials of construction are most frequently found in "SMACNA HVAC Duct Construction Standards - Metal and Flexible". UL 181-96, with addenda up to and including 1998, is a testing standard to which materials are certified, not a great deal of useful info there unless you plan on opening a test lab. Insulation and sealing requirements are typically found in something similar to the International Energy Conservation Code. Most of these Codes are based on standards produced by organizations such as ARI, SMACNA, ASHAE, ARE, UL, ASTM and ASME, amongst others.
Sorry for using that word...Duct...but I know some of you guys work on air also like us. New "code" for tape...UL181 etc. I am trying to find where these codes appear. What book are they in that will state r values etc. Any help would be appreciated.
Paul0 -
Check
Check under the Federal Energy Conservation code book....0
- 120 Geothermal
