wall hung boiler
Todd_12
Member Posts: 55
Take a look at the Weil Mclain Ultra, can be wall mounted and may be a good fit.
wall hung boiler
any imput for wall hung boiler from installing contactors, i have a project with 2 year old NTI T150C that has gone bad and need to replace all 24 of the units. anyone using a boiler that has given them good service for a number of years0 -
Vitodens
I've had very good success with the Vitodens. The venting requirements may have to be considered, as well as condensate drain. The Vitodens vents with a single 5" or 6" "co-pipe". The unit will also do DHW with an indirect tank and the DHW kit. The unit is extremely quiet, and can do multiple temperatures for zoning.
Hmmm
Two years old? What happened, and what was the response from NTI?0 -
Yeah! What Guy said!!!!!!!
Why do all 24 of them need to be replaced?
What happened?
Starch0 -
NTI
Specifics are important on this one. Why are all 24 'gone bad'? What are the cause(s)? & what response from NTI?0 -
water condition
water condition and flow rates are the key to keeping the wall hung units in good shape , were they set up with a combustion analyzer ? or just fired from the box , they usually quite after about 2 years if there not set up, they burn out the ignitor and other parts0 -
I can't get into the specifics due to the legal BS, however the flue connectors and collars are rotting off the units0 -
Wall Hung Boiler
I am considering a couple of Boderus GB142 for my project. Any one else have experience with these?0 -
See Paul's post
for a BS free solution.0 -
question
Are those flue connectors the ones with the screws or the welded studs?0 -
The early Trinity's did have a problem with the flue conections. It was a design flaw and NTI gave me free replacement parts. Improper installation and lack of attention will ruin any boiler, not just Trinity's.
Dave in DenverThere was an error rendering this rich post.
NTI is offering the updated, completely redesigned Trinity's. I'am a bit leary to resuse the same product because of all the issues. Has anyone installed them and if so how is the performace and how long have they been on line.0 -
boilers
Do you mean they are replacing the units on warrantee? Or offering them @ discount?0
- 120 Geothermal
