radiator pitch
Mark_68
The small radiator (20" X 14" X 5") in my bathroom spurts rusty water through the valve when heating up. There is also a lot of hammering. I've tried replacing the valve and correcting the pitch. This has not solved the problem. I noticed that the radiator is pitched back toward the wall a little. Could this be the source of the problem? Any help would be appreciated.
Spitting water
1st make shure the valve is open all the way. A partily closed valve will cause water to trap.
2nd if make shure your pressure is not to high. And if there is still hammering there is water there mixing with steam. I had a job yesterday that the short horz run under the floor to the radiator was trapping water the owner removed some risers from under the legs of the radiator. I raised the radiatior back up this lifted the pipe on the valve end and corrected the pitch problem. Just a idea hope it helps0 -
order [A pocketful of steam problems (with solutions)....
I had been wanting to order this book for a while and got it this week. It has already helped me on one job, if you have steam ?'s they are answered.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
- 79 Pipe Deterioration
- 396 Solar
