Rad valve Q. 1/2\" and 1\" on same valve
it seems as if you should try to keep what you have in the way of valves, and traps because of the pipe size on inlet and outlet. i have seen worse looking valve packing nuts, and yours should have no problem remaining leak-free, especially at the low pressure your system likes best [ounces]-nbc
  • TonyBal_2
    TonyBal_2 Member Posts: 54
    Rad Valve Q: 1/2\" and 1\" on same valve (and on same trap).
    I have a 1920s Illinois Eng Valve that was locked shut. I was able to dismantle and to my surprise fix the thing (I think).
    Q1 anyone know where I can get an old original round cap like one in the pic?? Or similar. Mine is fairly busted up.
    Q2. This one rad has this Valve with a 1/2" supply intake but a 1" out to the Rad. The WW 712HB Trap is just the reverse: 1/2" out and 1" intake.
    anyone heard of such a thing?? supply houses seem to know just 1/2" on both sides.
    I was considering replacing but now will go w/refurbish route.
    thanks
    GN Hoemowner
